Copy detail elements from link
hello all ,
I want to copy details elements ( Tags , dimensions , Filled regions ) from a linked file into the host file , is there a way to do it with dynmao or python ? given that the View in the host and linked file have the same name , and the elements are identical
thank you
Hi @sabra.tarek not really sure why instead of just custom revit links view so you see them…but try something here
yeah you actuelly dont need to pick or see them, but if you wanna see them on link then set your link display as show as link view…but here i dont see them and seems to work as well
Home.dyn (14.9 KB)
Here with owner view guess its better :wink:
Home.dyn (13.5 KB)
i am stuck in this for some reason it is not working with me , i appreciate your efforts with me alot tho. excuse me i am beginner in dynamo .if you have time here is the 2 revit files.
what i just need : is that in file ABC.rvt in section (555) the dimensions appear as they appear in file ABC details. rvt in the section named also (555). i tried the script you sent me but i dont know why its not working with me.
https://www.dropbox.com/scl/fo/ib4h9oic1udybq9onlmdi/AIgHE74_SrGrUaviyUhGYSA?rlkey=c9hp71bb6xxhte2l2zeaooxte&dl=0
no worries :wink: i can take a look tomorrow i will not be at dyn more today :wink: now its time for some more boring stuff :wink:
i tried link display as show as link view but it didnt work also
No problem at all! :blush: Thanks for letting me know. I’ll catch up with you tomorrow. Good luck with the “boring stuff” for now! :wink:
hehe cheers :wink:
Hi @sabra.tarek i can only see one fiilled region and one dimension on your link ??? is that right
¨something here maybe
Revit_lQj6JBCGvo
man you are a complete genius it worked , thank you a loooooooooooooottttttttt
Happy it could help :wink: but i dont recommend that workflow with annotate in different models :wink:
Thanks for the advice, but why you dont recommend it? or which workflow do you recommend
IMO its best only annotate in one model…when its same dicipline, guess its give better control…but just me maybe :wink: :wink:
sorry i have one last question does this dynmao script works also with Tags ? because i tried to copy Tags and get the result null as in the image attached. sorry again
yeah sure…that could probably be another situation, and will probably not so easy as we think…in this setup…i will take a look later :wink:
“Absolutely, it does seem like a more complex situation than it first appears. Let me know if you uncover anything interesting when you take a closer look! :wink:
Hi @sabra.tarek something here in that situation could work
r6vhTMeTX8
Home.dyn (52.4 KB)
