hi,
since Design Option and Revit Links are not open to API, i was wondering if i can export those values in the View Template to an Excel file and then import them back to another View Template?
i’d appreciate any help, thanks a lot.
hi,
Revit links are accessible through dynamo. The Rhythm package also has a node that allows you to access any Revit file given its path.(Application.OpenDocumentFile) You could simply plug the path from a linked file into that to open it and then use that document as an input when applying your view template settings.
I think he means the RevitLinks section of the ViewTemplate settings
hi @arshamm, you can try this way or use " Revit’s Transfer Project Standard ".
These nodes are from “Quasar Package”.
I guess I didn’t explain myself clear enough,
I linked 6 models into a project,
Each model has a few design options,
In the 3d view, I have a view template which all the links are set to their proper design option,
I also have different design options for floor plans and elevations,
Instead of modifying those design options one by one, is there a way to use Dynamo/Excel, to copy the parameters of RVT link from 3D view template settings to other ones (floor plan and elevation view templates)?
@jean, any idea how to fix this? The window is not dynamic and I can’t get to the “OK” button to move forward in the process?
@jean, another question too. Could one of your nodes be modified to be able to copy detail and model groups from one project to another? Thanks!
Hi @JustinStirling, if it’s the case, you can double click(edit) the custom node and type in a reasonable size as below;
@JustinStirling Yes, of course, you can always modify as you need. Like for instance: from this CopyLevelAndGridFromLinkDocument node, you can copy any other Elements instead of Levels & Grids.
Here is Package Repo : https://github.com/mgjean/quasar
Here is Package Info : https://twentytwo.space/quasar-package-guide/
Hi @EricRevit, there are two nodes, copy only selected & copy all. You are using the latter one to copy all.
