Convert Path of Travel lines to Curves
Hi All,
This might be a silly one but I am stuck.
I want to be able to convert the Detail lines created by the “Path of Travel” tool in Revit 2020 to Curves that I can use in Dynamo. I have tried every single node and nothing works.
You can see in the image below what I am referring to. Any help will be really appreciated!
Hi @german.bodenbender,
Use the Element LocationCurve node in Genius Loci package which works with all curve-based elements.
That was short and simple, thanks @Alban_de_Chasteignerfor the answer.
I had the package but an old version, after updating it it works perfect.
Thanks!
Thanks for the quick tip.
Hi, I meet the same issue. I can’t convert the line of “path of travel” to curve.
I have referred to your python script, but it is not workable.
May I get your help to solve this problem.
Jose
