I’m using the springs node that can create a filled region with multiple loops however I did not found the list logic that make it work with multiple floors. list member 0 is processed only the rest disregarded.
Any help appreciated.
FloorToFill.dyn (42.1 KB)
@daninet ,
check out EF-Tools from Erik, he shortly made a video…
KR
Andreas
Hi @daninet not sure could something here work
if you wanna split as in the video
or merge
Yes, I have tried this. It was the first thing I did. But the very same thing you have shown just produces a single fill 4 times.
FloorToFill.dyn (35.4 KB)
does it work if you select as here ? seems in your image you select the same element 4 times, but not sure as i cant see in your image whats goin on… if you want you are welcome to share your sample rvt
I catched the error, I accidentally passed through type element, not instance. Weirdly it didnt throw error but created one fill only.
