Filled Region Area to Room Data?
Hi All!
My goal is to pull the area data from a filled region and place it into a room/tag. I know this can be done with areas, but I was asked to make a variant for filled regions.
I’m hitting a bit of a wall here and I think its with my list organization, but I’m not sure. Hoping someone can give me a nudge.
I bootstrapped the code from this post to get me partway there:
But it falls apart at the point where it checks if the room contains the point. It should be working, I get one true value. I am working in a test project where there are only 3 rooms and 3 filled regions.
Here is a screen grab of the project:
Here is a screen grab of the script so far:
Here is a copy of the script:
Filled Region Info To Room TEST.dyn (32.7 KB)
I have more to add after this part starts working, but I want to get this squared away first.
Thanks!
You have no lacing or list levels so I’m guessing that’s your first problem. Try using list levels on Room.IsInsideRoom.
Perfect! Thank you! Apologies for the delay, things got crazy with the holiday!
