Hi all,
We are trying to create floors using dynamo.
We would like to use multiple loops or outlines for the same floor.
The only node that I have found Floor.ByOutlineTypeAndLevel does not seems to work.
is there any workaround or this cannot be done programmaticaly?
_Vijay
February 9, 2021, 2:50pm
2
Same topic have the solution in this Forum…
Thanks Vijay
Sorry but I cannot find anything
Thanks Vijay, we want to build floors not fill regions
_Vijay
February 9, 2021, 7:34pm
6
You need floor like a mesh, or it’s single floor mean in single plane
Hi Vijay,
We want to build a FLOOR
With multiple outlines per floor.
Multiple polycurves (outlines,loops) not one
_Vijay
February 10, 2021, 8:17am
11
can you show some images?
You have it in the first post, multiple outlines under the same floor
_Vijay
February 10, 2021, 8:22am
13
If try like this all inner curves will be floor cut. Do you want cut with all inner curves?
_Vijay
February 10, 2021, 8:24am
14
as per my undersetting you trying to create the floor like topo-surface with various level.
hello, have you guys found a solution for the problem?
Hello @zahafi14 and welcome, this post here is a bit old and many things has change for create floors…guess + 2022 you have option for create loops…guees rhythm and crumple have nodes there support that, try it and if it doesnt help you…just create a new post and share all your material so far
