Hello all,
I receive an ifc file with an in-place model which is identified as a slab. I want to convert this imported element in a Revit slab element in order to be able to work with it. Is it possible with Dynamo?
A second question, if I receive the 3D data of this slab is it possible to model it with dynamo as a Revit-slab? Because if I create a topography (create from import option) the problem remains as I could not join/cut the foundation with the topography.
I am new in Dynamo.
Thank you in advance!
