Hello, I’m new to Dynamo world and was tasked to create a Conduit Run schedule that had conduit from/conduit to, trade size(diameter), conduit type, run length and run id in the schedule. If you see the dynamo script I wrote its pretty straight forward but the issue I ran into is creating multiple of the same size and same type conduit runs but with different Run ID. I cant separate them. This had me scratching my head for a little bit. I came to the conclusion that I needed to get the Conduit Run system id. I researched and looked and couldn’t find any information. Any help or advice would be greatly appreciated.
CoHi, your graph is not visible. You should zoom until the block titles are visible and then export the image again.
Hi @jes.gonzalez, sorry for the late reply. I also need an image where the previews are visible, otherwise in your graph everything looks fine, no error messages…
