Conduit fitting length
Greeting everyone,
I am new to Dynamo and have been assigned a task to design a script to calculate length of a conduit fitting. I have an idea how it can be calculated on paper, however, no idea how todo it in Dynamo.
In picture above we have:
L - length we want to find;
a - angle of conduit fitting;
y - which is predefined value of 10mm;
x - radius, if conduit has a nominal radius of 10mm then x = 13.8mm, however, it would be good to implement formula to calculate x depending on nominal radius of conduit;
Total length of conduit fitting would consist of 2y+L.
Please, share your ideas, tips on how to solve this.
@vlad.aleksandrovs ,
that could be a starting point
grafik
LENGHT v2.dyn (21.6 KB)
@Draxl_Andreas
Am I correct that in terms of this script x must be created as a project parameter (instance) for conduit fitting? As well as L?
Also I am getting these errors while trying to recreate your script.
Hello
a solution using the CoordinateSystem of the connectors of the fittings (without extract geometry)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
def get_length_fitting(elem):
	return the arc geometry an the length
	if hasattr(elem, "MEPModel"):
		conSet = elem.MEPModel.ConnectorManager.Connectors
		if conSet.Size == 2:
			pair_sys_origin = [[con.CoordinateSystem, con.Origin] for con in conSet]
			pta = pair_sys_origin[0][1].ToPoint()
			ptb = pair_sys_origin[1][1].ToPoint()
			vector = pair_sys_origin[0][0].BasisZ.Negate().ToVector()
			arc = DS.Arc.ByStartPointEndPointStartTangent(pta, ptb, vector)
			return arc.Length
			return None #The fitting have more than 2 connectors
	return None #The Element is not a fitting
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstfitting = toList(UnwrapElement(IN[0]))
OUT = [get_length_fitting(e) for e in lstfitting]
@dr.hybride ,
Will the script work without custom node?
Reply to dr.hybride
Additionally, does this script lead end result somewhere to check it?
Hi @c.poupin ,
How does this solution work? Code runs via Python or …? I am not familiar with coding.
download MEPover in the package
yes, here the dyn file
get_length _pipe_fitting.dyn (6.4 KB)
@dr.hybride
Got it! Getting this warning now. Also where can I find the result of calculation?
Reply to dr.hybride2
thank you!!!
@c.poupin
Tried it, but the result doesn’t match the manual calculation.
Reply to c.poupin
Got it! But the result is way off the manual calculation.
Reply to dr.hybride3
he is getting the centre arc of the fitting, where you are getting the outer arc
do you know how to get the centre length from Tee too? :flushed:
may be because of the unite
yes, the arc is calculated according to the characteristics of the connectors
like the red curve in the picture below
if you need more length precision, this method may not be the best one, see the @Draxl_Andreas 's solution
nope, maybe to study
