Hello all,
I’m trying to write a python script to get the length of selected conduits and I’m running into a problem with the conduit fittings because they are of the FamilyInstance type which are not line based and so they have no curve to query the length.
I have a dynamo script to get the total length of selected conduit, and it has node (1-Element.Curves) that takes the selected element (elbow) as the FamilyInstance type (2) and returns an Arc and 2 Line objects (3) which can be queried for length.
Anyone know the function or method I can use to get the the Lines and Arc objects from the FamilyInstance object of a conduit fitting?
Thanks.
