Conduit by line not working - need help
Script conduitbyline not working with me.
Can someone help me please?
thanks a lot
Hello @soufiane.mel12 and welcome to the community :wink: im not really sure whats goin on, but i assume you select a line in revit …does it work if try as here ?
hello @sovitek , thank you for reception.
it does’t work, in the file Cad, i have lines and curves like the pict
Thank you,
Hi @soufiane.mel12 is it possible share that acad then we can try
thx for the sample…it will always be approximately as conduit can only be straight and not curved
Hi @soufiane.mel12 something here could be a start, the issue here is missing /unorder/overlapped lines so many thing can go wrong when the acad isnt is decent…play around with it :wink: or open the cad and try clean up
Hi @sovitek , hank you very much for your help, that’s work.
you’re right, when changing direction they use the box (chambre de tirage in frensh).
Thank you again
