Conditional Input from datashapes
hello
is there a way to enable/disable a part of a script (workflow) using datashapes.
i have a script that creates a view for each level in the model, i want the use to be able to decide whether to remove all views or keep them before starting.
i have checked the datashapes website, and according to the name “Conditional input” should do the trick, so i looked into it and the web page for it is empty:
UI.ConditionalInput Data - Data|Shapes (gitbook.io)
would really appreciate any input or a guideline to help me do the script
Hi @NERDASORUS do you mean something here ?
I see, so it changes inputs not what will be done on the script
thank you
Hello @sovitek , i have tried same as you did
It seems all the conditional input values are returned… even the disabled options (slider 2) is returned too
Is there a way to just return the picked options only?
¨Hi @najwan.joan.sv didnt know that :wink: but you could try something here in that case
