I’m trying to put together a graph to compare the host wall’s fire rating and the rating of any doors that are hosted in said wall. I can pull the walls & doors and get the parameters, but I’m not sure how to actually compare the results. Essentially I have:
Walls:
1 hr
2 hr
3 hr
Doors:
20 min
(should be rated)
90 min
At the most basic level I’d like to compare the lists and be able to pull out the element ids of the doors that are not rated if the host wall is rated. Long term It would be great to actually check if the door is the proper rating relative to the wall, but I’m happy with one step at a time.
I’m using the doors Aaron released a while back, not sure what the OOTB rating parameter is.
Doors-Compare Wall Ratings.dyn (26.1 KB)
Thanks!
