I figured it out. I had to set the List.Deconstruct node to use levels @L2.
Revit 2019.2, Dynamo Revit 2.0.3.8811, Rhythm, Clockwork, archilab, spring nodes
So here is my attempt to get several text notes by selection and then combine them all into a single text note so that I can utilize the OOTB bulleting features. This is where I have gotten but the error I get does not explain why it is failing.
Can someone take a look-see and tell me if they see where my problem is?
I can attach my .dyn file if it helps, thank you.
I should say in the graph I posted I was trying to create this graph using what was said in this post as well as this post: http://therevitcomplex.blogspot.com/2016/09/create-text-note-objects-using-ootb.html
After re-reading @awilliams post above, I just used hers.
I still would like to understand why my graph isn’t working. Maybe it would assist my Dynamo knowledge as a whole. =)
I would love it if you would attach your DYN file. I can’t find TextElement.Text.
sort by distance where can I get?
