I’m working on a Dynamo script to automatically place dimensions from structural columns to the closest grid lines. I’ve successfully found the closest grids and the preview lines show correctly in Dynamo, but the Dimension.ByReferences node returns null, and no dimensions are placed.
Here’s what I’ve done:
- I’m collecting columns and grids using
All Elements of Category.
- I calculate the closest grid to each column.
- The lines are visualized correctly in Dynamo’s background preview.
- The node outputs
null, and no dimensions are created.
What I need help with:
- Can someone help me find where the error might be?
- Are there common mistakes that cause
Dimension.ByReferences to fail silently like this?
And any good practices when doing dimensions in dynamo
Thank you
My initial thought is it’s a list @ level issue, I’d try setting both the Lines and Ref lines list at level to level 2. What does the list structure look like for your view and for your dimension type?
I’m not sure what you mean sir but here’s the nodes with list for dimension and view, I also tried changing the Ref Lines and Lines to level 2 in the last nodes
Btw here is my reference in that script
Okay, looks like the object type you’re using for dimension type is not what it wants. You’re passing a string when it needs a Revit element.
See if this resolves the issue, I’ll try to build a small sample on my end to verify that list at level is the issue.
That fixed the null problem
Thank you again @patrick_podeyn
Hi, angle, can you share you script.
I am also working on this and have some problems
May i ask, in that List.FilterByBoolMask, What is being searched for?
