I’m new to Dynamo and trying out the sunlight hours component and couldn’t figure out these two things:
The new ‘Generate Color’ node in later versions misses the ‘analysis surfaces’ input from the older ‘Color Surfaces’ node in earlier versions. What’s the way to input the surfaces using the newer node?
Is it possible to get these numeric values in Dynamo? I am trying to create a legend in Dynamo so that I know what the colors from the analysis mean. Thank you!
