Hello, I’ve drawn a solid in dynamo civil 3d and I need to add color, how can I do that?
Hola amigo @mateusc94 buenas. use GeometryColor.ByGeometryColor node, don’t forget turn off the preview of your original Geometry!! ![]()
I have answered very fast, if you have already created it in C3D just change the color of the layer in which you have inserted it.
I’m using GeometryColor.ByGeometryColor to assign a color to the solid I created. Now, I need to view the solid in Revit, so I used ImportInstance.ByGeometries and connected it to the solid. However, I also need to import the color to Revit. How can I achieve this?
I tried connecting GeometryColor of GeometryColor.ByGeometryColor to geometries in ImportInstance.ByGeometries, But it is throwing errors.
Hola amiga @Sandra.Raveendran buenas. que lindo nombre señorita!! ![]()
Try Override color in view, gemetry color works for Dynamo enviroment only!!
Personally i don’t use Import Instance, but if it works for you use it, i use FamilyType Bygeometry, and then Family Instance By point, i have much more control, i let yu the link for the topic, I hope this helps you my lady!!
Thanks a million for your guidance, good sir! As you told I used Family Type ByGeometry and then Family Instance By Point. Then, I applied Override color in view, and guess what? It worked like magic. Thanks again for your help, sir.¡Muchas gracias, amigo!
Amiga @Sandra.Raveendran buenas. My lady I’m glaad to hear that it works for you, keep going to improve your dynamo skils.
and welkome to the dark side!!
