ByGeometryColor
Hi, there!
I am trying to output colored objects to Civil3D. I have combined “ByGeometryColor” with a solid. In the Dynamo space, the color appears, but it does not display in Civil3D. I think the way to connect nodes might be wrong. is there any solution?
Color the autocad object after creating it in C3D using the Object Set Color. You need to feed in the solid object so use the output from the object by geometry node.
Or set the color of the layer that the object is on.
Thanks for your advice! The objects I made was successfully colored in Civil3D space.
