Hey guys.
I’m having an issue. I made points by grid and connected them with lines, after that I used Solid By Sweep, to make the lines gain some width, but then I try to give somo colors to it and when I use Element Override Color, it accepts my color range, but not the solids, or the lines I made previously. What should I do?
Element.OverrideColorInView is a Revit specific node - which means you’ll need Revit objects for it to work, not Dynamo objects.
Back to the topic of color in Revit - is there any way to write materials to elements as opposed to the override?
Currently I sort by color and then write to element types pre-defined with that color as their type material. Would be cool to simply write materials to elements by providing RGB values.
Thanks!
*More here: http://dynamobim.com/forums/topic/how-to-color-panels-by-image-file/#post-14151
