Hi All,
Is there a specific node to get a color based on code i.e where I input (1,2,3,…) and get (red, yellow, green ,cyan…). The only node I have seen is color pallete where I select from a list.
Hi All,
Hi!
If you want to pick by RGB values
Or if you want to select by name (clockwork package)
You could make if statements, or use a small dict to link colors to your number input
You can also build a list of the colors (using by ARGB or via the pallet), and then use a List.GetItemAtIndex.
