Codeblock display error. Dynamo 2.16
I made a script that was working before I went on vacation.
Now that I want to work on it my codeblocks dosn’t display the data i put in. The graph still runs and works as i should, but cant find the reason for this error.
I have checked on a coworkers PC here it displays correctly. I have tried to unistall the revit completly but with no effect on the issue. Have anyone encotred this problem before?
This is a sign of a DLL conflict, usually the result of a Revit add-in or package.
  1. Close Revit and restart your CPU.
  2. Disable all Revit add-ins
  3. Rename the DynamoSetttings.xml and packages directory found in %appdata%/dynamo/Dynamo Revit/2.xx/ where xx is the Dynamo build you’re currently using (ie: udpated Revit 2022 would be 2.16). This will prevent any customizations to your package paths and any pre-loaded packages to not load.
  4. Launch Revit, and start a blank project from no template (select none in the drop down), and set the units to imperial
  5. Launch Dynamo and open your graph.
If the issue persists check your Revit journal for add-ins which weren’t disabled (search for vendor; only Autodesk, adsk, or some variation thereof should be present). If nothing was missed post the .dyn, your dynamo log file, and your Revit journal.
If the issue doesn’t persist restart again, undo the renaming of the settings and package path (you’ll have to delete the new versions), and repeat steps 3 and 4. If the issue still doesn’t re-occur we can confirm it’s an add-in. If the issue does re-occur you can start checking your installed packages in small groups until you identify the issue.
If it’s narrowed down to an add-in, confirm you’re using the latest version of all add-ins. Then restart Revit and disable in small groups until the issue no longer persists.
It was def the add in issued it resolved it self after removing add ins. Thank you Jacob
