Clockwork 1.x (When will this be available)
Hi, I’m working on a slab using the Floor.Slab.Shape.ByPoints node by Clockwork. It seems to not function in 1.1.. The package manager has an install for up to 0.9..
My question is when will the new package be ready? It seems that once I select Dynamo 1.1.0 it locks me out of selecting a previous version during my session of Revit.
Thank you.
P.S. This is a great node.
Clockwork for Dynamo 1.x is in the works, but I haven’t had much time for it recently. So far, I have tested and migrated about 75% of the nodes.
You can track my progress here: https://github.com/andydandy74/ClockworkForDynamo/tree/master/nodes/1.x
It is likely your issue has a different reason, though. Please check your list of installed packages for older versions of Clockwork and/or a package called Turn Into List and uninstall those.
I uninstalled the package “Turn Into List” and it seems to work now.
Thank you.
Looking forward to the new package. :slight_smile:
By the way, you might want to check if you have any of the listed packages installed and get rid of them:
Just to let you know:
Clockwork for Dynamo 1.x is available as of now.
Older Clockwork packages are no longer supported.
Please upgrade now.
Don’t forget to uninstall older Clockwork packages!
Version history: https://github.com/andydandy74/ClockworkForDynamo/wiki/Version-History#101
Post issues here: https://github.com/andydandy74/ClockworkForDynamo/issues
