Clashing with Duct - Pipes/Cable Tray offset.(45 degree)
Deall All. Please help fix and improve the dynamo script to connect.
45 degree angle at bottom.
UP DOWN Duct_45.dyn (105.4 KB)
Hi @WSAMAN you could try something here…
Thanks you. Best Regards.
Yeah thanx for your PM, try follow the video, and see how far you can get and then show us here where you are stuck in an image with all nodes expanded…i have actuelly done it for a company and wouldnt be fair, just give it away here…try create your own :wink: cheers
There are too many nodes. Do you have a step by step for this?
no not really…but a good start is mepover and openmep package, but keep in mind there are difference if we talk pipe/ducts vs Cabletray/conduit as we cant split but need rebuild in my experience and connect to fittings again
Do you think is it possible to avoid the clash if the ducts are in linked model?
yes i do :wink: if it not that one you will modify…try it and if you go totally stuck…then show whwre and we can try help
