90_Cable Tray.dyn (101.3 KB)
Hey @WSAMAN that split node doesnt work for cabletray or conduit…se description in node…you could try split the location curve and rebuild the run
Thanks for the advice, I’ll try it.
¨Hi @WSAMAN you can try something here should work on cabletrays and conduit and dont break the system
Thank you very much.
Dear K. Søren Villadsen. As for the cable tray, the angle will be 45 degrees. The power tray is at a 45degree angle. What should do? Thank you very much.
In the case of using a 90 degree cable tray, an error has occurred. What should do? Thanks you. Best Regards.
hard to say as i cant see your image…
Up_Down_90_CableTray_test.dyn (110.4 KB)
Hi try do exackly what i show, when its a 90 you wil need find the locations normal and rotate, on 45 you dont need that…i dont think i can go deeper in that, now its up to you play around with it…as the forum isnt "do my job place " …
…Thank you very much. ฺBest Regards.
Hi @WSAMAN thats a new topic i have already give you for 90 and 45 vertical…so please create a new topic…thanks
thank you very much. ฺ Best Regards.
