Hi!
So, I have a slight problem with a particular node from package CivilConnection by @Paolo_Emilio_Serra1 called ‘RevitUtils.SampleLinesParameters’. Until 5 minutes ago I could create sample lines in Civil 3D of which stations I could use to put down my family instance. I always used this node but for some reason it doesn’t work anymore. As you see in the pictures below, sample lines are created and the previous node correctly reads baseline but stations under the problematic node are ‘Empty list’. Anyone know the problem?
The problem is still there even if I use a slightly different node called ‘Alignment.SampleLinesParameters’.
I am using:
Dynamo 2.6.1
CivilConnection 2021 5.0.5
Revit 2021.1.2
Civil 3D 2021
Thank you!
