CivilConnection incomplete shape generated
I ran across this problem when i’m trying CivilConnection. Some of the shapes (kerb) are not completely generated in dynamo space and the top 2 pavements of the road corridors are also not generated.
Any work around for this?
Thanks!
Have you set the working range to medium as specified in the documentation?
Hi Paolo,
Thanks! That worked!
Hii @albert.lagumbayan - I am able to get adaptive family in Revit. Could you please tell me which node you have used in order to get solids inside dynamo (Perhaps “Element.Geometry” is not working in my case?
Looking forward to your reply.
Thankyou!
With Geometry set to medium for me it wouldn’t work and gives me error for baseline. When I have the larger corridor is not built completely and it is discontinued. See the pictures below. any solution to this?
This has also to do with the structure of your corridor, please attach the civilconnection log (not the dynamo nor the revit journal file) as well as the xml with the corridor name. Also you are not very experienced with CivilConnection, so don’t try to guess what the tool is doing wrong, because you don’t know. the scale needs to stay on medium that is an order.
Where is the civil connection log. I am very inexperienced in both dynamo and civilconnection.
%TEMP% folder, read the documentation
Thanks,
I just went and saw the civilconnect temp file. I found places that the profile failed to generate the geometry. Any recommendation?
I need the files
I ran it with both large and medium setting and the link is attached. I am not sure how to send them here.
CivilConnection_temp-medium.log
CivilConnection_temp-Large.log
https://chiengineers-my.sharepoint.com/:u:/p/sfazli/ESvdna0YaZdNpwNa5MNTDTIBgCjTNprNte3cBG2cOkn3rw?e=g9L51a
turn off all the baselines except one, rebuild the corridor and try it again
there are cross sections too close to each other.
pass only the start and ending station to begin with
I get better results now that I use only one of the baselines instead of all three (one by one), but still get the same error for range. and also when I run it for other base lines it rewrites it.
THE RANGE IS NOT AN ERROR!!! I wrote the package so please trust me leave it on medium
I will leave it at medium, also thank you a lot for writing the package. It works better with one baseline and there are only a few places that I can manually add later. Thanks.
By any chance do you know how to remove the shape from the family? The code produces this type of shape and when I try to edit the family it doesn’t exist.
Is there a way to create the corridor in revit as floor/roof or some cuttable section
The Generic Models category supports cut, you can use the MultiPoint objects in CivilConnection to create either adaptive components or floors
Do you know how I can cut the generic model? Based on my search online and autodesk apparently it is not possible to cut them.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-3253EFCA-F38F-4086-9A4D-C873D8D04867
do you need to cut a floor in a plan view? the generic models in Section view support cuts, just open Revit and check for yourself
