Excellent job
Looking forward to try.
Do we have nodes to create pressure pipe?
Excellent job
Thatâs good news Paolo, thank you!
Awesome⌠Looks promising, will test it out soon.
Not in 2020
Yes, I have been managing the transformations with the basepoints/surveypoints and rotations manually as of now.
I will try with SAT Export. Thanks for the information.
Can we have for Civil 3D 2021. Is there separate package?
When you will have time it would be great to add nodes to consult, create, edit and modify corridors regionsâŚ
Looking forward to it
Hi Paulo, I donât know why, but almost every time I use the node ânetwork.getpipesstructuresâ Dynamo freezes, sometimes for hours and that doesnât happens when using getbyname or IterisCivilDynamo package.
I tested in several different computers and in several different routines, thatâs not specifically to one pc, file or routine.
@deividsteffens please share the dataset you are using.
Hi @Paolo_Emilio_Serra1 this solves my problem. Also i successfully managed to set new values with 1500 plots. It took about 1.5 hours to finish, not sure if that could be improve or thatâs normal considering the number plots. Please see attached log file for your reference. Thank you. Log file
@myrwen.junterealSJC7 thanks for the feedback, the log shows that setting the properties and updating the values is the part that takes considerably long time and that the performance starts to degrade after roughly 200 objects (2 sec), then the next 300 (2.5 sec) and so on up to 4 sec for each property.
Could you split the inputs into batches of maximum 200 elements each and maybe use Dynamo Player to see if there are any improvements?
Do you have any nodes to extract corridor solid?
@eden no as far as I know it is not possible with the .NET API
Hello! First of all, HUGE thanks for developing this pack, itâs a real improvement for our performance! Weâve started the creation of some scripts and they look promising.
I wanted to ask if there is any node to export civil3d models to Navisworks file, Iâve been looking for it but I canât find it within this package, not sure if I am missing something or if you could add it as a future improvement for next updates.
Many thanks for your continuous support!
@v_rivas thanks for the feedback, could you please start a new thread with this topic as it is not currently part of the package and could you also articulate the use case you have in mind?
Noted, please see link below
Thanks @Paolo_Emilio_Serra1 for your reply. Do we have any nodes to create pressure pipe network for Civil3D 2021?
@Eden I have not yet had time to look into 2021 API
