Hello all
Has anyone tried this?
I tried but it doesn’t work for me
How to get to API com
Blockquote
FOR CIVIL 3D 2022 “AeccXUiLand.AeccApplication.13.4”
import sys
#clr.AddReference('Autodesk.AECC.Interop')
clr.AddReference('Autodesk.AEC.Interop.UIBase')
clr.AddReference('Autodesk.AECC.Interop.Land')
clr.AddReference('Autodesk.AECC.Interop.UiLand')
clr.AddReference('Autodesk.AEC.Interop.Base')
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
import Autodesk.AECC.Interop.Land
import Autodesk.AEC.Interop.Base
import Autodesk.AEC.Interop.UIBase
import Autodesk.AECC.Interop.UiLand
Document = IN[0]
Databaseel = Autodesk.AEC.Interop.Base
DatabaLand = Autodesk.AECC.Interop.Land.AeccSites
from math import *
import System
from System import Array
Databaseel = Autodesk.AECC.Interop.Land
CAD =System.Runtime.InteropServices.Marshal.GetActiveObject("Autocad.Application")
CADCC =CAD.GetInterfaceObject("AeccXUiLand.AeccApplication.13.4")
DOCv = CADCC.ActiveDocument
DOCNAME = DOCv.Name
DOCdata = DOCv.Database
output = []
for Surface in DOCv.Surfaces:
output.append([Surface.Name])
for Site in DOCv.Sites:
output.append([Site.Name])
for Alignment in DOCv.AlignmentsSiteless:
output.append([Alignment.Name])
OUT =output #Database
