Dear all, Dear @zachri.jensen
I hope you are all doing very well,
I am trying to extract pipe network geometry using Camber nodes, and I Hope you can help me with the following topic!
I am trying to use the Camber nodes ExternalBlock.Objects and get the pipe network Geometry by connecting to ExternalObject.Geometry. Please see screenshot
I wonder if this Camber node ExternalBlock.Objects are suitable for C3D Pipe Network, or it is created only for Autocad objects, and If I am using it correctly.
As you see from the error message, the Node has indicated that the geometry has not been implemented for this object type!
Thank you very much for your help and support
Kindly regards
Salwan Abbosh
Hi @S.Abbosh,
No, unfortunately pipe networks have not been implemented with the external nodes. ![]()
