Choosing mepfitting with mepfitting.bymepcurves
Hello i want to thank the mepover package, it helped me, i had a question, i have been creating a script to avoid beams with conduits, i want to know if there is any way to choose the type of join between two pipes by type of family, because i want to enter a box between two pipes and not an elbow my knowledge of python is still little, or is there a node that has that function?
The node will place the elbow family that is specified in the routing preferences of the pipe type. If your box family is an elbow family then you could specify it in the routing preferences. I think that would be the easiest way to go.
Hello, thanks for your answer, checking I realized that it is created in the form of a Tee and it worked. One question, is there a way to edit the code to rotate it 90 degrees in the z axis and generate it in that position?
