Changing Wall Thickness using dynamo
Could anyone suggest how to change the wall thickness through Dynamo?
Clockwork has some nodes but I haven’t had any luck in my brief attempt. You could do it with Python though. You just have to get the layers from the wall type and adjust the width there.
You can use the following nodes from Clockwork Package to get the job done.
Capture
ChangeWallThickness.dyn (16.7 KB)
Thanks Amol, I did and it worked.
Hi @AmolShah, does this script only change the layers inside the wall?
Thanks for this, It works great.
RHD-DYN-REV-RedSea_Wall_Floor Changes.dyn (97.8 KB)
I have used a couple of scripts to do a repetitive change on 22 models, thanks for the info.
null…mmmm…any thoughts?
@Gcf_Design Please share a sample Revit file with the family loaded into it so I or someone here can take a look at it.
Are you in Revit 2022?
If you’re using Revit 2022, a solution :
