Hello everybody,
Im trying to change the Position and the Thickness of a Wall Element in the same Script.
When changing only one at a time the script works fine, but when attempting to change both at the same run revit is not able to do so:
Error message: The constraint are not satisfied
For the change of the wallthickness im using the Clockwork node as suggested in this post:
SeanP
2
Try using a Transaction.End and then Transaction.Start node between the two functions.
Thanks for your answer.
There is no connection between those 2 function as they both end in setting the values.
So i dont know where to put those Transaction nodes exactly.
I tried to get a Connection between those 2 functions but i still get the same error.
Can you try the “Passtrough” node? or “Await” from Orchid package.
Thanks @SeanP and @Deniz_Maral this made it work:
