Hi all,
I want to translate shared parameter files, so I translated directly into the text file of the shared parameter file to keep the same GUIDs. I’m looking for a way to update my project with these new settings labels, is it possible?
Hi all,
Thanks Alban,
I don’t want to recreate, I want to update the project parameter associated with a shared parameter whose label I have changed in the text file.
It is not possible to rename the project parameter associated to a shared parameter once it was created.
You can change the Parameter Name in the shared parameter file, but this will have no effect.
The best is to transfer the parameter values to a new parameter with the new name and delete the old shared parameter.
On the other hand, for shared parameters in families, there are well-known workarounds.
Can you tell me which ones ?
Hi @Remy_Maurcot maybe look at that:
Replace Shared Parameters
Cheers
Try Crumple the great package from @GavinNicholls
Cheers
I don’t think Dynamo is the most suitable tool for this task.
I’ve posted here but I’m not necessarily looking for a dynamo solution, if I have to create a program to do it I’m fine with it.
Thanks for your link
