Hello, is it possible to control via dynamo the dimensions of the (Parts
at node view (“Element Parameters Property” coming from GeniusLoci package) i would say not (read only) changeable only from revit interface.
Can any of you confirm this or not?
Cordially
christian.stan
It’s actually possible to offset faces of a part via the API, but it is not as easy as setting a parameter.
I have not personally looked into working it out, but as a start you can check out this class: SetFaceOffset Method
Hello, and thank you for looking into my problem, no need to go further upstream on your side, it’s up to me to work much more intensely (to progress)
thank you again for your answer
I credit your answer as the solution.
Cordially
christian.stan
