Hello Dynos,
i found to this topic some kind of solution in C#. How can i set a new basement for rooms.
so when i do it manualy:
1.) delete room
2.) place the deleted room it in the right view β Level
3.) height correct
Does anyone have a workflow in dynamo?
i struggle also with Revit2024 Dynamo:
#test
import sys
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI.Selection import ISelectionFilter, ObjectType, Selection
selection = uidoc.Selection #type: Selection
# π classes
class ISelectionFilter_Classes(ISelectionFilter):
def __init__(self, allowed_types):
""" ISelectionFilter made to filter with types
:param allowed_types: list of allowed Types"""
self.allowed_types = allowed_types
def AllowElement(self, element):
if type(element) in self.allowed_types:
return True
# 0οΈβ£ PickElementsByRectangle
selected_elements = [doc.GetElement(e_id) for e_id in selection.GetElementIds()]
selected_rooms = [el for el in selected_elements if type == Room]
if not selected_rooms:
filter_types = ISelectionFilter_Classes([Room])
ref_picked_rooms = selection.PickObjects(ObjectType.Element, filter_types)
selected_rooms = [doc.GetElement(ref) for ref in ref_picked_rooms]
print("Please select a Room")
import sys
sys.exit()
currentBasement = [p.get_Parameter(BuiltInParameter.ROOM_LEVEL_ID).AsElementId() for p in selected_rooms]
OUT = selected_elements, currentBasement
it can`t see ISelectionFilter
KR
Andreas
