IFamilyLoadOptions / CPython3 Issue
I’m currently working on a python script within Dynamo that will batch load families . It works as is in IronPython ; however, when I switch to CPython I get a TypeError : interface takes exactly one argument line 58 (the famDoc.LoadFamily(doc,FamilyOption()) line). It appears to be related to the FamilyOption Class, but can’t seem to figure out how to fix it. Any thoughts?
class FamilyOption(IFamilyLoadOptions):
    def OnFamilyFound(self, familyInUse, overwriteParameterValues):
        overwriteParameterValues = True
        return True
    def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues):
        return True
def ChangeCategory(doc, element, bic):
    # Retrieve the family from the given element
    family = element.Symbol.Family
    TransactionManager.Instance.ForceCloseTransaction()
    famDoc = doc.EditFamily(family)
    ownerFamily = famDoc.OwnerFamily
    # Change the category of the owner family to a new category, in this case, Windows
    ownerFamily.FamilyCategory = Category.GetCategory(famDoc, bic)
    # Define new subcategories to be added to the family
    newSubCats = ["Glass", "Trim", "Frame/Mullion", "Sill/Head", "Panel"]
    TransactionManager.Instance.EnsureInTransaction(famDoc)
    subCats = ownerFamily.FamilyCategory.SubCategories
    subCatDict = {}
    for s in subCats:
        subCatDict[s.Name] = s
    for w in newSubCats:
        # Add new subcategory if it does not already exist
        if w not in subCatDict:
            try:
                newCat = famDoc.Settings.Categories.NewSubcategory(ownerFamily.FamilyCategory, w)
            except: pass
    # Start a new transaction in the main document to load the modified family
    famDoc.LoadFamily(doc, FamilyOption())
    return ownerFamily
Hello @criddell
it’s a current PythonNet issue
see here.
use IronPython 2 or 3 instead (you can build a C# library too)
Ahh , yeah that is where I was headed. Thanks for confirming .
There is a cpython 3 / pythonnet hack that I have seen @jacob.small use. Interface subclassing appears to work with a unique namespace
import uuid
    __namespace__ = uuid.uuid4()
        return True
        return True
interesting… I’ll have to try that out. Thanks for the reply!
for info, this hack (under PythonNet 2.x) seem only works correctly with certain Net Framework components
in Revit 2024.2 (or 2025 beta)
hence my previous reply
