Categories node Error
Hello I have a script that transfers my sat. files to revit. I have opened up in my new computer and the categories node gave an error. I remember downloading a package before. I forgot which one it was and not sure if this is
Make a python script:
OUT = Revit.Elements.Category.ByName(IN[0])
Actually it should work, it is builtin Parameter!
2022-04-21_17h31_11
2022-04-21_17h40_54
KR
Andreas
thank you for response but havent use it before. I dont have the categories node
at least it works as work arround…
Which dynamo version do you use?
sometimes is an IT issues and installation path
2.3.0
do you know a package that could be in @Draxl_Andreas
https://dictionary.dynamobim.com/2/#/
or make a python-script, if it has to be fast.
thanks but still didnt get the hang of it :frowning:
Do you know what python nodes are? or cabable off?
actually in dynamo you can recreate every node by your self! you have just to copy paste my code - that was it.
Do you use Sandbox or do you use Dynamo Revit?
