Help error in a python node
Good morning, I had this routine but it wasn’t me who developed it, and in an attempt to use it in revit 2025 it is reporting this error, could anyone help me?
import math
clr.AddReference("RevitAPI")
if isinstance(IN[0], list):
        fittings = UnwrapElement(IN[0])
        toggle = 0
        toggle = 1
        fittings = [UnwrapElement(IN[0])]
def getConnSysType(connector):
        domain = connector.Domain
        if domain == Domain.DomainHvac:
                return connector.DuctSystemType.ToString()
        elif domain == Domain.DomainPiping:
                return connector.PipeSystemType.ToString()
        elif domain == Domain.DomainElectrical:
                return connector.ElectricalSystemType.ToString()
                return None
p = []
dir = []
fd = []
ref = []
conns = []
descript = []
H = []
W = []
R = []
MEP = []
Sys = []
Shap = []
sysClass = []
for fitting in fittings:
        points = []
        direction = []
        flowdir = []
        refs = []
        connlist = []
        description = []
        height = []
        width = []
        radius = []
        MEPSystem = []
        systemType = []
        shape = []
        systemclass = []
        try:
                connectors = fitting.MEPModel.ConnectorManager.Connectors
        except:
                try:
                        connectors = fitting.ConnectorManager.Connectors
                except:
                        p.append(None)
                        dir.append(None)
                        fd.append(None)
                        ref.append(None)
                        conns.append(None)
                        descript.append(None)
                        H.append(None)
                        W.append(None)
                        R.append(None)
                        Shap.append(None)
                        MEP.append(None)
                        Sys.append(None)
                        sysClass.append(None)
                        continue
        for conn in connectors:
                connlist.append(conn)
                description.append(conn.Description)
                try:
                        height.append(conn.Height)
                        width.append(conn.Width)
                        radius.append(None)
                except:
                        try:
                                radius.append(conn.Radius)
                                height.append(None)
                                width.append(None)
                        except:
                                radius.append(None)
                                height.append(None)
                                width.append(None)
                shape.append((conn.Shape).ToString())
                try:
                        MEPSystem.append(conn.MEPSystem.Name)
                        systype = doc.GetElement(conn.MEPSystem.GetTypeId())
                        systemType.append(systype)
                except:
                        MEPSystem.append(None)
                        systemType.append(None)
                try:
                        systemclass.append(getConnSysType(conn))
                except:
                        systemclass.append(None)
                points.append(conn.Origin.ToPoint())
                direction.append(conn.CoordinateSystem.BasisZ.ToVector())
                try:
                        flowdir.append(conn.Direction.ToString())
                except:
                        flowdir.append(None)
                for c in conn.AllRefs:
                        refs.append(c.Owner)
        p.append(points)
        dir.append(direction)
        fd.append(flowdir)
        ref.append(refs)
        conns.append(connlist)
        descript.append(description)
        H.append(height)
        W.append(width)
        R.append(radius)
        MEP.append(MEPSystem)
        Sys.append(systemType)
        Shap.append(shape)
        sysClass.append(systemclass)
if toggle:
        OUT = points, flowdir, refs, direction, connlist, description, height, width, radius, MEPSystem, systemType, shape, systemclass
        OUT = p,fd,ref, dir, conns, descript, H, W, R, MEP, Sys, Shap, sysClass
import math
clr.AddReference(“RevitAPI”)
toggle = 0
toggle = 1
return None
p = []
dir =[]
fd =[]
ref =[]
conns =[]
descript =[]
H =[]
W =[]
R =[]
MEP =[]
Sys =[]
Shap =[]
sysClass =[]
points = []
    direction = []
    flowdir = []
    refs = []
    connlist = []
    description = []
    height = []
    width = []
    radius = []
    MEPSystem = []
    systemType = []
    shape = []
    systemclass = []
    try:
    except:
            try:
            except:
                    p.append(None)
                    dir.append(None)
                    fd.append(None)
                    ref.append(None)
                    conns.append(None)
                    H.append(None)
                    W.append(None)
                    R.append(None)
                    Shap.append(None)
                    MEP.append(None)
                    Sys.append(None)
                    continue
            try:
                    radius.append(None)
            except:
                    try:
                            height.append(None)
                            width.append(None)
                    except:
                            radius.append(None)
                            height.append(None)
                            width.append(None)
            try:
            except:
            try:
            except:
            try:
            except:
    p.append(points)
    fd.append(flowdir)
    ref.append(refs)
    H.append(height)
    W.append(width)
    R.append(radius)
    Shap.append(shape)
# 🏈 Assign your output to the OUT variable.
if toggle:
paste your code to
grafik
The ToString() method is an old IronPython method. You can use str() instead, which is the standard Python method to stringify a value.
myValue.ToString() => str(myValue)
I don’t understand, should I paste this text on line 106?
You should replace the ToString() method with the str() method wherever it’s used.
it’s a Pythonnet2 issue, temporarily try this workaround
                return System.Enum.GetName(DuctSystemType, connector.DuctSystemType)
                return System.Enum.GetName(PipeSystemType, connector.PipeSystemType)
                return System.Enum.GetName(ElectricalSystemType, connector.ElectricalSystemType)
                return None
this is fixed with PythonNet3 and as I indicated in this example
alternatively, you can also use IronPython3
none of the alternatives worked
Ok - why didn’t they work? What was the error message? Can you post what you tried?
https://drive.google.com/drive/folders/1jVU1d4r1Subjih8IMe9zC3ED6Q6E4f7Q?usp=sharing
here in the link above is the rvt file and python so we can observe the erro.
see now
Hi @tiago_cslsemobs
following your last dyn, you switcjed the engine to IronPython2 so it seems that you have another problem
  • try to reduce the number of nodes
  • if the problem persists start a new topic with the dyn and the rvt file (it is missing in your link)
I apologize, I already attached the rvt file to the link
After switching Revit to Portuguese and running your script with your Revit file, I don’t see any errors. Make a new topic if necessary
yes once it works but after you date the revit and open the project again it stops working
There are some issues with the code:
Overwriting buitlin types and imported classes dir and MEPSystem with empty lists will cause errors.
Rather than trying / excepting are there checks in the API?
Here’s how to get connectors with a function
def get_connectors(element):
    # Requires an element with connectors
    if isinstance(element, FamilyInstance) and element.MEPModel:
        return element.MEPModel.ConnectorManager.Connectors
    if isinstance(element, MEPCurve):
        return element.ConnectorManager.Connectors
I’ve taken the liberty to refactor your code
Refactored code
from System import Enum
from Autodesk.Revit.DB.Mechanical import DuctSystemType
from Autodesk.Revit.DB.Plumbing import PipeSystemType
from Autodesk.Revit.DB.Electrical import ElectricalSystemType
        return Enum.GetName(DuctSystemType, connector.DuctSystemType)
        return Enum.GetName(PipeSystemType, connector.PipeSystemType)
        return Enum.GetName(ElectricalSystemType, connector.ElectricalSystemType)
    # Element is not a fitting or MEP element
    return str(type(element))
fittings = UnwrapElement(IN[0]) if isinstance(IN[0], list) else [UnwrapElement(IN[0])]
results = []
    connectors = get_connectors(fitting)
    if not connectors:
        # Element does not have connectors
        results.append([[fitting.Id, connectors]] + [None] * 13)
        continue
        item_results = []
        item_results.append(conn.Owner.Id)
        item_results.append(conn)
        item_results.append(conn.Description)
        item_results.append(Enum.GetName(ConnectorProfileType, conn.Shape))
        if conn.Shape == ConnectorProfileType.Round:
            item_results.extend([None] * 2)
            item_results.append(conn.Radius)
        elif conn.Shape in [
            ConnectorProfileType.Rectangular,
            ConnectorProfileType.Oval,
            item_results.append(conn.Height)
            item_results.append(conn.Width)
            item_results.append(None)
            item_results.extend([None] * 3)
        if conn.MEPSystem:
            item_results.append(conn.MEPSystem.Name)
            mepsystype = doc.GetElement(conn.MEPSystem.GetTypeId())
            item_results.append(mepsystype)
        item_results.append(getConnSysType(conn))
        item_results.append(conn.Origin.ToPoint())
        item_results.append(conn.CoordinateSystem.BasisZ.ToVector())
        item_results.append(Enum.GetName(FlowDirectionType, conn.Direction))
        item_results.append(list(conn.AllRefs))
        results.append(item_results)
# Check for single result
if len(results) == 1:
    OUT = results[0]
    # This will return a list of information collected by connector
    OUT = results
    # This will return a list of information collected by values
    # Order of values:
    # fitting, connector, description, shape, height, width, radius, mepsystem, mepsystemtype, systemclass, origin, direction, flowdir, refs
    OUT = zip(*results)
Good morning, which of the nodes did you modify, can you put the file here?
I reviewed the code at the top of this thread.
I did have a look at the dyn, however I could not untangle the logic to be able to provide a review.
You can use the code in the drop down
your code didn’t work
I mean, the python script node isn’t showing an error. Nor can we see that’s happening as the previews below the node are not visible. Its not easy to tell whats happening here when you dont show the output nor the error messages
