Hello! In Dynamo i can see the downloaded addons but i cant seem to uninstall them?
Also how can i see what version of an addon i am using?
Here is no way of saying exactly what addon or version it is and also i cant uninstall them.
Thanks! ![]()
Thanks! ![]()
@lasse ,
you have to close Revit.
Navigate to the package folder and delete the unwanted packages!
reopen Revit/Dynamo you can start or update your packages.
KR
Andreas
Go into your package settings (newer builds itMs under preferences in the Dynamo menu) and you can see which packages are installed there, including version. From this point you can remove packages as desired, but packages which utilize zero touch nodes will require a restart of Revit.
Thanks !
Thank you for the detailed explanation ![]()
