Code doesn’t open at all. When I open file I don’t get any code blocks. On the other hand it is working and opening on colleague’s computer. It is specific only for programs that colleague has made. Default programs from software itselft are opening and working.
I don’t have any packages. Or I don’t know what do you mean by that?
I have additinal sowftares for revit.
I don’t get any errors. Simply software doesnt open a programs. Or it opens and all interface is empty
Can you do a quick screen recording showing what you see and post it to a file sharing service of some sort?
If not we’ll need some more questions answered:
Can you open Dynamo or do you not see the window at all?
Can you start a new graph from the Home Screen and place a few new nodes and wires, or it’s it just blank?
Can you open other graphs, or just the one from the colleague?
When you open the graph, do you see any change in the UI?
Once you try to open, can you access the Dynamo menu at the top?
You could also try reaching out to my colleagues in support by submitting a ticket on the accounts portal at Manage.Autodesk.com.
Do you have the same Revit Version? If you create a .dyn-file in Revit 2023 it can occure that you can’t open it in Revit 2019 for example. Happened to me with a .dyn-file i created myself.
