I’m creating a filter to get all column with top level from active view’s level. I was able to create a filter of equals rule type with my current script but the value of the level was null. I think it has something to do with the type of value of the FilterRule.ByRuleType node. I tried to use Level, Level name, Element ID but has not been successful. Can someone tell me what I’m missing here.
Can you try Level.ByName and conncect from Level 3 to get level and connect it to the value?
What can you select in window if you do without Dynamo? and did you try to connect directly from string from object node?
Okay, the problem is: Level in Filters are in API different. I remember that situation from that post.
You should use Python to get levels there.
Oh yes I think this is what I need. Thank you very much for pointing me in the right direction
