Filter Rule non String
So I’m struggling to get my filter rule by rule type working…
I want to filter by Level, so I believe I need to feed both the Level Parameter (ie. a parameter) from the floor and the Level Parameter value (ie. a string).
My attempts at retrieving the parameter by name don’t seem to be working (I create a rule but the value is blank) so I’m trying python… But I don’t seem able to return a parameter?
import sys
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
elem = UnwrapElement(IN[0])
pName = IN[1]
outPut = []
p = elem.Parameters
for n in p:
	pvp = ParameterValueProvider(n.Id)
	#if pvp.IsElementIdValueSupported(elem):
	if n.Definition.Name == pName:
		outPut.append([n.Definition.Name, pvp.GetElementIdValue(elem), doc.GetElement(pvp.Parameter)])
OUT = outPut
Any thoughts welcome…
Cheers,
Mark
View Filter Set Create Add Check.dyn (104.6 KB)
I don’t think GetElement works for parameter elements. You could probably use something like GetParameters or LookupParameter instead.
Thanks Nick,
I’m wondering if I’m looking at the wrong problem… I think the filter rule should work if i put the level in, but it only returns a filter if i put in a string (the level name)…
I’m seeing if i can doctor this code…
Correct. The input is actually a string here, which is backwards from how the Level parameter would normally work. It’s working on my end.
I find it makes a rule, but when i go look at that in Revit, it’s empty?
[Hopes it’s just me]
You’re right. Blank for me as well. I’m guessing it’s because the FilterRule node expects a string but the value for Level is an element. I’m guessing this will have to be fixed in an update.
Thanks!
I don’t think i have that node!
I’ll go update my package now…
I have Archilab 2019.2.11 are you on a more recent version?
No I’m on an older version. It doesn’t seem to work either. The rule gets created but the filter doesn’t.
Hum… It’s not there,
I’m messing around with the Python but getting this message, probably because I’m using a string equals filter…
But I can’t see a create method for a filter rule that isn’t a string?
https://www.revitapidocs.com/2020/c8c02bc8-5318-812c-e0f2-bc5dd5d2ad64.htm
# Import RevitAPI
clr.AddReference('RevitAPI')
# Import ToProtoType, ToRevitType geometry conversion extension methods
# Import DSCore nodes in Dynamo
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
# Import python library
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import os
import shutil
import math
# Import math library
from math import *
#Import Data and Time
from datetime import datetime
now = datetime.now()
#Import System Library
import System
from System.IO import Directory, Path
app = uiapp.Application
def ToList(x):
	if isinstance(x,list): return UnwrapElement(x)
	else: return [UnwrapElement(x)]
pName = IN[0]
elem = UnwrapElement(IN[1])
filtNames = IN[2]
cats = ToList(IN[3])
catids = List[ElementId]()
catids.Clear()
for cc in cats:
	catids.Add(cc.Id)
test = []
p = elem.Parameters
for n in p:
	test.append(n.Definition.Name)
		ePvp = pvp
		break
#define subset of element filters
sfilters = List[ElementFilter]()
sfilters.Add(ElementParameterFilter(FilterStringRule(ePvp,FilterStringEquals(),pName,False)))
#define final set of element filters
fRule = LogicalAndFilter(sfilters)
#Do some action in a Transaction #
for name,cat in zip(filtNames,cats):
	paraele = ParameterFilterElement.Create(doc,name,catids)
	paraele.SetElementFilter(fRule)
	Parafilele.append(paraele)
OUT = Parafilele
View Filter Set Create Add Check.dyn (115.4 KB)
maybe you can should your final desired output of the filter rules and i will try and help you to code with it?
Note that in R18 and above, it uses different approach as compared to R17 and below. And the sample code you got is for R18 and above
And also, i dont think you need to feed in an element to retrieve the parameter Id, you can either use parametermap for project or sharedparameter element and filter by name to retrieve its Id
Thank you for offer, I am trying to achieve this…
I want to make a filter rule which uses Elements (Levels)…
Right now I can only make a filter rule which uses Strings.
Cheers :slight_smile:
Mark
may i know on which categories you wanna apply that filter to?
Floors :slight_smile:
EDIT:
There doesn’t seem to be an… if value.GetType() ==typeof(element)
Just ints, doubles and strings…
if (value.GetType() == typeof(int))
                    System.Reflection.MethodInfo methodInfo = typeof(ParameterFilterRuleFactory).GetMethod(methodname, new[] { typeof(ElementId), typeof(int) });
                    if (methodInfo != null)
                        return new FilterRule((Autodesk.Revit.DB.FilterRule)methodInfo.Invoke(null, new object[] { parameterId, (int)value }));
EDIT EDIT:
Seems I need to go right back to create the parameter filter with a different method?
ParameterFilterElement Class
https://www.revitapidocs.com/2020/b231dc85-516a-5e75-c634-c6cd81b43fc5.htm
CreateEqualsRule Method (ElementId, ElementId)
https://www.revitapidocs.com/2020/13332eda-1822-237d-51a6-d09df09b5234.htm
EditEditEdit:
Doesn’t like it…
This seems relevant…https://forum.dynamobim.com/t/python-custom-rules-for-filteredelementcollector/21135*
And another fail :slight_smile:
Bit of progress…
Gotcha!
The first BIP LEVEL_PARAM didn’t work, it needs the 2nd… I’ll have to run some kind of check…
pId = ElementId(BuiltInParameter.SCHEDULE_LEVEL_PARAM)
sRule = ParameterFilterRuleFactory.CreateEqualsRule(pId, level.Id)
fRule = ElementParameterFilter(sRule)
OUT = Parafilele
Sorry for the late reply but it seems that you had already figured out. Good for you! but since i already sort of did it already, here is another way to achieve what you want for R19 and above(my above reply is wrong)!
pvp1 = ParameterValueProvider(ElementId(BuiltInParameter.SCHEDULE_LEVEL_PARAM))
#Empty list of Element Filter
sRule1 = List[ElementFilter]()
#Get all levelids in project
lvlids = FilteredElementCollector(doc).OfClass(Level).ToElementIds()
#You can use this loop to retrieve desired level, just change to ToElements() and search by name
#We can filter by element Id and since element id is numeric, we will use FilterNumericEquals()
for lvlid in lvlids:
	sRule1.Add(ElementParameterFilter(FilterElementIdRule(pvp1,FilterNumericEquals(),lvlid)))
#Can use LogicalAndFilter
fRule = LogicalOrFilter(sRule1)
#Get a list to cat ids to be used by the filter
catids.Add(Category.GetCategory(doc,BuiltInCategory.OST_Floors).Id)
#Create the ParameterFilterElement
pfe1 = ParameterFilterElement.Create(doc,"Example view filter1",catids,fRule)
#Final output
OUT = pfe1
And for R18 and below:
#Empty list of FilterRule
sRule1 = List[FilterRule]()
	sRule1.Add(FilterElementIdRule(pvp1,FilterNumericEquals(),lvlid))
pfe1 = ParameterFilterElement.Create(doc,"Example view filter1",catids,sRule1)
#Final output
OUT = pfe1
This is to just check, if the value provided is int or string or double, you will notice they use sort of different methods for different type
Thanks for posting the code.
Yes, they check for int string or double, but they don’t check for element… Perhaps I’ll drop that on the github as a request.
One thing I found was that while SCHEDULE_LEVEL_PARAM works, LEVEL_PARAM didn’t… i need a filter :slight_smile:
Cheers,
Mark
Final Graph…
View Filter Set Create Add Check.dyn (98.5 KB)
Well… for this i do not have control over it as it is determined by the Autodesk team. If you use revit lookup, you will be able to find which builtin parameter the level is tied to. hahaha
