Unable to patch this curve
Thanks in advance
Loft bottom and top curve? Might work?
The top yellow node needs a list of 2 curves as an input. Use the up and down curve and the flat curve at the bottom. Feed into List.Create node then feed this list into Loft.ByCrosssections node
hi
use NurbCurve instead of PolyCurve
as of Dynamo 2.8 - polycurves should be able to be converted directly to nurbsCurves without resampling.
Flatten the list.create node output.
Thanks Jacob for ur solution, and for other members for dedicating your time for helping. The great community!
