How to loft parallel curves
Hi!
I have parallel curves, I want to loft surface through them. Dynamo fails to loft it. Any idea what can I do?
2022-07-13 10_54_10-AE7 PC - AnyDesk
@daninet ,
what do you mean with parallel?
I was assuming “CrossSectionCurves” means they need to have a cross section. My curves does not have they are on parallel planes
@daninet when they overlap it can`t be generated
mines do not overlap
surfacelines.sat (18.0 KB)
Please share an image showing your entire graph.
that is my entire graph on the first image I manually selected the lines. In my previous post I have included the lines as a sat file please try to loft them
Ahh I see the problem. You have 9 nurbscurves in your list when there should only be 6.
I manually resorted them.
Good luck.
Loft.dyn (23.7 KB)
Yup this was it. thank you
