Hey guys, I have some problem using Dynamo topography by points nod. I am using select model element ,selecting topography from revit and connecting it to topography by points.
I can see a list of points but I can not see any visual preview in the Background 3D Preview.
Hi @stav1233 !
Did you use the node Element.Geometry ?
I Tried it.
Doesn’t seem to work.
Welcome to the community…
Have seen similar issues in the forums… there are lots same issue solved in this forum.
you should share a screenshot of your graph
Hey _Vijay can you reference me
did you “zoom to fit” (ctrl b then zoom to fit) ?
i did
i believe its got something to do with graphics defention.
not working:(
I have the same issue & I tried everything as mentioned above. Any other possible solutions
Post what you are seeing, and the background preview setting of your system as a start.
I solved by installing latest version of Direct X and Graphics. Thanks a lot to all forum member.
