Use dynamo when I use category to get stair support elements, it is not working in Dynamo. I try to find any solution, but not get it.
Have you meet this problem or any suggestion.
Very thanks.
Here are is a script snapshot.
Can you provide a simple model - say one stair with two supports - and the dyn posted above?
Hi Mr.JacobSmall, Thany you for reply, the blow is more description and the sample model and dyn for us. (Revit2018.3 & Dynamo 2.0.2)
Stair support test.dyn (16.3 KB)
Many thanks for you.
And here is Revit file for test.
Stair support test.rvt (1.8 MB)
Hi Mr.JacobSmall
Have you find any information about this case.
I look forward to your reply.
Haven’t yet, but it’s on my list.
How is it going? I’m looking for the same solution!!! Need separate Data from Stairs- Support and Stairs-“Läufe” (in German)
