I’m looking to get a Revit Category and its Name in a list, only for a few categories, and this is the best I can do. Can you point me into the most convenient direction?
Thanks,
Jason
Try the element.name(universal node) which is in the clockwork package. Not sure it will work though.
Here is one way to do it. See image and attached example graph:
Categories & Names.dyn (5.6 KB)
Thanks John @jmmiller , What pkg is Revit_Elements.GetRevitCategory from?
Found it. Simplex; Thanks again!
@Jason_Trahan if you found your answer please mark the post as solved. Thanks!
