Callout change parent view
So, to my knowledge it’s not possible to change the callout’s parent view.
I only want the callout to be visible on a specified view (and the callout was put on a wrong one).
So moving a callout … should be ‘changing the parent view’ … which only gives me the one it was created on. I figured: dynamo … but it won’t let me either. Did you guys ever tried this?
Hi, it’s actually possible in two (or more) ways:
A) You open the callout you want to move and set the parameter for the active view
B) You create a list of views (callout) and set the parameter for all of them
Doesn’t work because “Parent view” is read-only and can’t be changed.
