Calculat areas automatic from revit
How can I use nodes and files in Dynamo to automate the calculation of specific surfaces like Floor Area and Habitable Surface in my Revit model? Can you also provide definitions for Floor Area and Habitable Surface?
Let’s start with the definitions:
Floor Area: In architecture, construction, and real estate, floor area refers to the total area occupied by a building or a specific part of it, measured in square feet or square meters. The definition of floor area can vary depending on what elements of the building are included, such as external walls, internal walls, corridors, stairs, etc. There are three main ways to measure floor area:
Gross Floor Area (GFA): This is the total floor area within the building, measured up to the external face of the external walls.
Gross Internal Area (GIA): This is the floor area within the building, measured up to the internal face of the external walls.
Net Internal Area (NIA) or Usable Floor Area (UFA): This is the GIA minus the floor areas occupied by certain elements like lobbies, machinery rooms, stairs, mechanical and electrical services, lifts, columns, toilet areas (except in residential properties), ducts, and risers.
Habitable Surface: In the context of the French Code of Construction and Housing (R111-2), Habitable Surface (SHA) is defined as the constructed floor area after deducting the areas occupied by walls, partitions, staircases, ducts, door and window openings. It does not include unconverted attics, cellars, basements, garages, terraces, loggias, balconies, outdoor dryers, verandas, common areas, and other outbuildings of housing. Additionally, parts of premises with a height less than 1.80 meters are also excluded from the calculation.
Hi Noura,
This sounds possible, but by rules of the forum you must take the challenge yourself first and then come back to this tread when you are a stuck on something.
There are plenty of other topics on this forum related to this that can help get you started :slight_smile:
thanks i will do it then share it with you :innocent: :blush:
