CAD.ReportInstances (Bimorph) to report linked files (RVT as well as cad), also missing links
I haven’t used dynamo in a really long time and just started with it again.
I have to check a revit project package for all the revit and cad links to organize our workflow.
And this needs to be done for like 20 revit project files.
Luckily I though of Dynamo and I knew of Bimorph node for this.
however I am getting null results. Maybe because the links are missing?
I tried it with existing projects and even there it returns me null results.
I am sharing a screenshot maybe there is a stupid mistake I am doing and someone can help me point that out?
Thanks for your encouragement.
I found some thing:
Tried it. It works but I am encountering errors to export it to excel. just gives me a warning and a blank xml export.
Got it, Was missing the item field to the List.AddItenToFront node. Works flawlessly.
I got it this far:
But I got two issues:
  1. It doesnt work when i specify the file from the file Path node
  2. It doesnt export the element ID waht is reflected in the Watch list with a green highlight.
Any ideas? Thanks for your help.
I just checked and the optional input Filepath works for me.
Use the Filepath input in a blank Revit file and not inside your “17010_002_BF2.rvt” file.
To export the ID, you must add the Element.Id node to the graph.
elem%20ID
I think the link you wanted add in post 2 was this :
Hey,
You are right.
Thanks for the tip. i was wondering why dynamo doesnt work without any Revit file open.
Works like a charm with a blank revit file.
thanks again.
My next step is to scale it a bit bigger, I mean instead of choosing a file each time, make it perform a batch operation, Like I specify a folder and I picks all the revit files in the folder and makes a excel sheet.
This is useful to investigate broken links in Projects.
Will post when i am a step in that direction.
Thanks again for your help.
